2002 Bayliner 3055 - Converting from manual to an electric 12V toilet. Panel has no available breakers. What is best method to create power source?
3055 electric-gctid807962
There is a good chance down the road that you will want to add other things as well.
I would install a new DC panel. I would run a new negative and positve to the new panel. This way you are not overloading the already taxed system.
You will need a breaker to connect to your house load (on the common side if the MBSS).
https://www.bluesea.com/products/805...ion-Slate_Gray
And welcome to the forum!
Joel
1987 3818 Hino 175
"Knotty Girl"
Prince Rupert B.C.
Ditto the new DC accessory breaker panel.
I would prevent this new "amp hungry" circuit from pulling power from the OEM hull harness.
I would suggest taking both a new Positive and Negative circuit forward, sizing them appropriately for the electric head and for future loads as well.
Rick E. Gresham, Oregon
An alternative is to run a wire from the MBSS to a surface mounted circuit breaker in the engine compartment and then to the head. Make sure that you use an ignition protected breaker. also, size the wire to ensure that the voltage drop is low. If you envision connecting other accessories in the future, you can run a heavy gauge wire from the MBSS to a buss bar and from the buss bar to the appropriate breakers.
https://www.bluesea.com/products/713...face_Mount_25A
https://www.bluesea.com/products/718...face_Mount_25A
2013 Boston Whaler 130 SS
Isla Verde, PR
