I just bought last week a 1991 Bayliner Capri 1850 with a Mercruiser 3.0 (Serial #: D428186) When I bought it, it fired up and ran in the guy's driveway on muffs. He had rebuilt the carburetor, installed a electric fuel pump prior to the mechanical pump, but it had not been in the water for a couple of years.
A week later, I went to start it to get the oil warmed to change it and it won't stay running. It starts and runs for about 5-10 seconds at most, then dies. I'm going to do a complete tune up on it and see if that helps.
However, while I was doing some initial troubleshooting, I found that the voltage at the coil was 5.5V. Searching tells me that it could be 12v or 6v depending on the ignition (I have a points ignition) . It has a purple wire coming to it, is that the resistor wire? What should the voltage be?
