PLEASE HELP SUPPORT OUR SITE
This old gal is still making lots of HW with 120 volt but seems to come up short when heating from the engine circ. Oh it heats up but only to about 70 degrees. My question.. Is there a limiting thermostat in this unit that would try and keep the water from reaching engine temp, ie 180 degrees or so.
Or is it just time for a new tank..
Thanks much.
1988 3870
Hino 4 cyl 210 turbos (upgrade)
Hull extension
LIves in Powell River
Thanks much.
It should reach engine temps.air lock maybe.
Thanks much.
Don't think so, the hose is hot on in and out of the tank. maybe if I hook it up backwards it may flush out and debris..
1988 3870
Hull extension
I think you have either a block in the flow, or stuff hanging on the coil of the hot water tank. I think it's the flow since there would be similar deposits on the coil.
I'd try flushing the engine line out to see what the flow looks like.
"Foster" post=816365 wrote:
Even with 11 gallons of cold water (
+1 Also check to make sure there isn't a valve in the line between the engine and the water heater. I have seen occasions where valves were added to both the inflow and outflow lines. If there is a valve it might not be open all the way. Have experienced that before too.
Greg
Newport, Oregon
South Beach Marina
