Hey guys how is everyone doing. Put the boat in the water two days ago but one of my engines starts to get hot when I'm under way. A idle the temperature stays steady where it is supposed to be once I give it gas or go underway it rises and extra 20 degrees I just put new manifolds and risers new thermostat new raw water pump any ideas thank you. I have raw water cooled 5.7 bravo 2 carburetor engines
TEMP GETTING WARM-gctid807011
Did you change all these items because you were having issues previously? Were the current exhaust shutters functioning or replaced during this time? Was there one missing? All hose connections good at the intake side of the raw water pump?
"THE FIX"
'93 2556
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
"THE FIX"
'93 2556
My engine temp started to rise before I did anything I checked the engine while running with a temperature gun found the issue was the gauge
Boat in the water or drive fully submerged, remove the hose off the pump, you want to place the hose into a bucket, start the engine for 15 seconds shut down the engine, measure the water in the bucket.
Like chief said, your measuring the volume of water the raw water pump puts out (outlet side of pump) Try a new t stat first.
"THE FIX"
'93 2556
"sketch96" post=807174 wrote:
Bravoitis!
"THE FIX"
'93 2556
The alfas have a spot where they collect salt, between the leg and the bell housing. I'm not sure if the bravos are the same or not. Otherwise you've done all the stuff I can think of.
Chay
Just talking with a friend of mine and he was having the same trouble he put thru hull fittings going to the pump and eliminated the pickup from the outdrive. He's very happy with the results. If it is the pickup from the outdrive going to the pump on the engine I might put the thru hull fittings in
