I've read on here and it seems that people have quite a few different ways of mounting, and different types of silicones and adhesives that they use.
I recently purchased a Garmin Striker 4 fish finder
I was having issues with my depth finder transducer and the repair shop wanted about $500 to replace my other stock transducer after parts and labor.
So I opted to buy an inexpensive fish finder solely for the depth finding purposes. However, I have a tough time drilling into my transom, so I opted to mount it thru-hull. According to the people on amazon they've had luck mounting this thru hull with no issues.
I was curious which ways you all did if, if you've done it. I've head I can seal it in pic pipe with mineral oil and then mount the pipe, others said they've used silicone to mount it in the bilge. So I'm just trying to figure out the easiest most effective way of doing it that won't cause issues.
Any input is appreciated.
Thanks!
-Mike
Thanks!
-Mike
