When shifting from Forward to Neutral and also from Reverse to Neutral, i hear a grinding noise as if the clutch is not engaging correctly. If i move the shifter forward or back a bit the noise stops but i also cant tell if it then goes into gear.
Could this be a shifter cable adjust issue or low fluid level? something else maybe.
Any help would be appreciated
