PLEASE HELP SUPPORT OUR SITE
Thanks!!!!
Bad experience with JR Marine Swivel Shaft Repair?-gctid806289
I'm doing my due diligence on options for fixing my Bravo 2 shaft seal leak. So far I only see positive feedback on the JR Marine approach to accessing the swivel shaft nut. Has anyone had a bad experience with this? Anyone's cover plate ever leak? Not been able to get the shaft out? Any other major pitfalls?
The JR method is a good way to do it if access is tight on the engine bay side (seems most are) A couple things I did different was to put a slight curve (very minor) into the cover plate as the area of contact is not completely flat, and I opted to use marine grade urethane as the sealant instead of sillycone. The shaft may be corroded into the gimbal ring but penitrating oil and pacience is your friend with that issue
Has anyone bought the Jr marine or nuwave stainless swivel pin and just tried fitting the steering arm on it before installing it in the transom assembly?
I just bought a new arm and pin. Put them together on the bench and torqued the pinch bolt. The pin falls right out. Does not cinch up to the pin tight. I would have thought that they should be tight?? Am I missing something? Is it supposed to be that way??
Doug
496 big block - Bravo ll leg
The Doghouse
Prince George BC
Sketch, it should be a tight fit after tightening the bolt. Was the steering arm a mercruiser /Sierra part? I found my SS shaft on eBay (I'll see if I can find the one) and it was a snug fit without the bolt installed.
My only recommendation would be to use higher quality 3/32 drill bits. I started on mine yesterday and the first hole I drilled was for the cover cap head screw and the bit broke off. I'm not sure what to do at this point as its almost impossible to drill hardened steel from soft aluminum. I continued with drilling the window holes and the second bit supplied with the kit broke on the third hole. I used one of my drill bits from a drill index and finished the remaining holes with out any further breakages. Everything else in the kit seems to be good quality and the people at JR Marine are very helpful and knowledgeable. I ordered my kit on Thursday and it was delivered on Saturday.
1988 Mainship 36 Sedan
1995 2858
1988 2655
1987 2150
Commercial/Industrial HVAC Service Tech.
I have a jr marine window kit if anyone is looking. Bought it to do on the boat but when I decided to do a new transom I had to pull the motor and transom assembly off anyway so access is not an issue.
Pm me if you looking.
Doug
The Doghouse
Prince George BC
