I have an 87 2550 Ceria with a 5.7 OMC under the deck.
It started running really poorly the other day and upon investigating it I discovered that my number 7 cylinder has only 60 psi of compression while the other 7 cylinders are 175 plus. I squirted oil into the cylinder and the reading didn't change at all so I am assuming it is valve related.
My question is can I safely remove the head with the boat in the water or will the open exhaust system flood the boat.
Thank you.
Thank you.
