I drilled the holes to install the Smart Tabs on my 2006 175 and water began to come out of the lowest hole I drilled on the starboard side of the transom below the waterline. Not too much - streamed out and then was only dripping about 30 seconds later. The water was not in the bilge but underneath of where the battery sits.
I did not end up installing the tabs for a few days in hopes that whatever was in there would come out. later I drilled another hole a bit lower and more toward the center line on the hull/transom and water still came out the same way it did before from the other hole.
I installed the Smart Tabs a few days later but ended up leaving the lowest hole (the one I drilled later) open and stuck a paper towel in there to see if I could draw any more water out. I left it over night and about half the towel is wet.
So I have two questions:
1. How bad of a problem is this? And, how do I fix it?
2. I used 3M 5200 Marine Adhesive to seal the holes. Will this be sufficient? I'm having a bit of anxiety about these holes below the waterline in addition to the water in the hull.
