454 RAT MOTOR-gctid805272
    ok sports fans
    how hard and how expensive is it to change big block raw water cooled to closed loop cooling
    kevin
    Mercruiser?
    What year?
    Half cooling or full cooling?
    Fresh water engine or salt water engine?
    Carb? MPI?
    900 to 1300 not shipped.
    If salt water block there will still be rust in the block which can plug the heat exchanger.
    http://www.michiganmotorz.com/mercru...38_82_114.html
    Boatless at this time
      not sure jsut looking but its a lake superior boat......1988 40' convertible...dont know what fuel delivery sys it uses...its a silverton
        Fresh water boat leave it alone.
          Why?
          Pat. Sandpoint Ida
          I NEED ANOTHER BOAT!!
            I think what he means is... if it is staying in fresh water leave it as is.
            1979 32 Uniflite Sport Sedan twin 270 crusaders
            2003 Bayliner 2152 210 Classic 5.0 mercruiser - sold
            I wish I knew now what I didn't know then
              But closed cooling will let him boat into freezing weather or am i wrong?
              Pat. Sandpoint Ida
                thanks all for the replys
                will be using the boat in superior till sept ,then start the trip to tenn, with side trips up the cumberland , then the tenn, were hoping to get to pensacola ,, but with raw water cooling may have to forego that part of the trip. then sell and call the buckit list for boating complete. thanks again for the replies
                kevin
                  "bkc914" post=805272 wrote:
                  ok sports fans
                  [color]#000088 wrote:
                  Kevin, if you are fairly mechanically inclined, the task can be simple. With the forum member's assistance here, you can do it!
                  As for expense...... it will depend on if a new or used system, and/or if a Full or a Half system!
                  A Full system includes exhaust manifolds, whereas a Half system excludes the exhaust manifolds.
                  Exhaust Elbows will always be Raw Water Cooled!
                  As mentioned here...... existing rust scale will need to be monitored. I would suggest operating the new Closed Cooling system for XX hours and then removing and dumping the H/E coolant contents into a clean white 5 gallon bucket. Monitor the rust scale debris.
                  Repeat this in XX hours until the rust scale debris becomes minimal!
                  A Closed Cooling System allows for more than just freeze protection. Your cabin heater and water heater will now function more effectively, and will no longer require the coolant side to be drained upon decommissioning for winter.
                  .[/color]
                    Why?
                    Pat, I would ask the same thing!
                    If Kevin wants to inquire and possibly do this........ let's help him! [/color]
                      Well there is still some fresh water that can freeze. So if you think its now protected and nothing needs to be done, that would be wrong.
                      Is it worth doing under the projected use?
                      Maybe not.
                      Even if it hits salt, it is starting as a new motor with the problems salt creates. A system will last for years raw water cooled. Depending on the use and age, the engine and related cooling may outlast the engine mechanical life.
                      On the plus side of doing it. As it is a fresh water boat it can be added. If it spent its like on the Great Lakes, there will be no rust damage in the cooling system that will cause problems. .If it were a salt water boat the rust would continue and most likely clog a cooling system.
                      So if your going to do it, now is the time.
                      Is it worth it? Well only you can judge that.
                      Doug
                        I did post a link to the MM site with different kits.
                        MM has treated me awesome when I ordered my new engine and cooling kit.
                        And the prices are the same as others. Installation is a snap if you are mechanically inclined at all ( or have a buddy that is)
                          Fresh water boat stays in freshwater i would leave it alone !
                          Didn't i post that already ?
                          Boat gonna be kissing saltwater the first time, then add the cooling system.
                          The Mutt, Doug alot of guys have installed them.
                            Let's all try to keep in mind that Kevin did ask; "how hard and how expensive is it to change big block raw water cooled to closed loop cooling?"
                            My responses have been per the question.
                              Yes it has !
