Hello Everyone! First of all, I am completely new to power boating and planning to buy a VR5 with a 115hp OB. I looked a lot on the internet to get an answer if hydraulic steering is worth the extra money. From the Bayliner webpage it appears that the mechanical setup is actually power steering? So I am wondering what actual benefits the hydraulic steering has and if it is indeed worth for a 20 ft boat with a 115 hp engine. Also, i am no sure if the standard steering has a no-feedback setup or not. We would be using the bot mainly on the inter coastal around Miami. Thank you all in advance and I hope my questions are mo too confusing. If so, then the reason is quite simple - I am confused.
