Help!! Motor runs smooth till it hits about 2500 rpm then it sputters and shakes. Happened suddenly when i was cruising on the lake at about 28 mph the engine just started to slow down and running rough. I was able to limp back to the boat ramp at just above idle speed. I replaced all the gas (portable tank) this weekend after the problem and the low pressure fuel filter but still runs rough and shakes at anything over 2500 rpm. Only 60 hrs on the motor. Any suggestions on what to check?? I dont want to trek to my dealer if i can avoid it....
Thanks Jeff
