Hello all, I am in need of some help here,
Let me start by saying Thank you to lou!! He has spent hours with me trying to help and I really appreciate it!!
boat info.
88 5.0 litre, omc.
NEW aftermarket outdrive. Maybe has 10-15 hours total on it. Roughyl 2 years old since it was replaced now.
Let me explain how this all began, Last August I took her to the lake. Reversed her off the trailer and put in neutral. She stayed in reverse. I found that the Shift cable had been stretched at the end that hooks the engine side. Since then I have purchased a New lower shift cable, New control cable and even a new control (the seastar one). For the life of me, I can not get this thing to shift correctly. I have read hours upon hours from Lou, Bounty and midnight wolf. I have midnight wolfs tools. I have tried bountys "unorthodox way". I have tried everything that Lou has spent hours trying to help me with. I think that my problem here is that I am not getting enough motion in the lever on engine side to fully put her in gear (both forward and reverse..I need to know how to fix this, I have attached pics of my lever, that is the neutral position in the pics ... So what i mean. If put the control into forward gear, The cable doesn't pull the lever far enough back to fully put the drive in forward gear, Vice versa for reverse. It doesn't quite put the lever far enough forward to achieve reverse.. Now, If i put the control lever in either gear and go down to the lever on the engine and push the extra amount my drive will fully engage in both directions as it should, but only if I give the lever on the engine a little push. Its off about 3-5 mm in both directions from fully engaging. It will come out of gear perfectly and go back to neutral as it should..
Any help at all from the pros here would be appreciated. I am desperate to fix her.
boat info.
88 5.0 litre, omc.
