Hello everyone. The pressure switch in my wash down pump is not functioning. Essentially the pump is always on when I turn the breaker on. The boat came with a bunch of spare parts including a new pump. The pump I am taking off is reated at 45 psi and the new pump is rated for 55 psi. Will I run into issues if I put the higher pressure pump on? I don't really want to blow a line or a fitting. Or am I overthinking it?
Thank you.
Jamie
Thank you.
Jamie
