windshield wipers bayliner 32-gctid804293
    Hi
    I am trying to replace the wiper arms on my Bayliner 32. The original arms and wipers are made by Trico. I am concerned about buying the wrong arm and having them not fit on the spline motor arm. The wiper arm is 15inches long.
    Why do you want to replace the wiper arm? If the arm is ok you could just replace the
    wiper blade. Should be able to get a blade at any auto store. Remove the bolt the arrow is pointing to and bolt on a new blade.
    1999 Bayliner Ciera 2655
    5.7 Bravo 3
      I use automotive arms and blades, may depend on the connection at the motor.
        The splines are the same as automotive.
        Greg
        Newport, Oregon
        South Beach Marina
          thanks....
