My potable water pump has had a very small leak when pumping and lately
It has gotten much worse. It is spraying water from the bottom of the pump when the switch is on. Its probably time to replace it.
My question is: What would be a suitable replacement for the existing pump? My main concern is finding pump that will have the same size fittings and connections. Those of you that have replaced the pump, what did you replace it with?
