Hi Guys,
We are having a bowthruster fitted to our 2855, & whilst it's out of the water I have decided to sort the trim gauge. Replaced & adjusted the gauge sender & woohoo, we have a fully functioning gauge, OK, so far so good. Reads fully down & all the way up to fully up
Problem I have is I have done the limit switch, (this never did anything ever before), checked with a multimeter & have the sensor switch off at, (think the instructions said 554mm eye to eye on the ram but left them at the boatyard) This is showing at appox halfway on the trim gauge, (Does anyone know if this is about the correct cut off, I have no idea on a safe level of trim on the leg???) but the leg doesn't stop so looks like someone has messed before to bypass it.
I dont suppose anyone has a wiring diagram for the sensors do they?
Cheers, Shane
Cheers, Shane
