How to remove 3055 windshield wiper arm-gctid397055
    Hi, My wiper arms are starting to look a little weather beaten, I am not sure if they were painted or powder coated but they need re-coating anyway, I just need to get them off first. Any tips please ?
    On my 4087, I removed the nut at the arm mount, then used a small puller to remove the arm from the motor shaft. I made a puller which is very similar to a battery post removal tool. Use some liquid wrench or similar product as there will probably be quite a bit of corrosion.
      Flip up the end caps and remove the nut holding them in place. Now wiggle them until the pop off. They are mounted to a splined shaft FYI. A good coat of tremclad lasts about 5 years. Been there, done that.
      Cheers, Hans
      2007 Carver 41 CMY
      Twin Volvo D6-370
      Montreal, Canada
      Midnight Sun I Photos
        Thanks for your reply. What's tremclad ? as I have never heard of it. It might be a product not available over here
          Just a popular brand of rust resistant spray paint available throughout North America. Did not realize your location.
          Cheers, Hans
          2007 Carver 41 CMY
          Twin Volvo D6-370
          Montreal, Canada
