Unfortunately my circulating pump pulley revealed itself as drunk during spring startup and service. I noticed she had a good wobble and had been wearing the belt. Is it possible the wobble is just a bad pulley or is it definitely the water pump itself that needs replacing? I removed the pulley and the water pump spins smoothly when I turn it by hand.
I have the capacity to replace the pump I guess I just need confirmation that is the best place to start.
To confirm, I am dealing with the circulating pump in the center of the engine, not the raw water intake pump at the lower starboard side of the engine!
Thank you!
Thank you!
