Replacement switches-gctid802709
Probably won't find that exact replacements with the screws but Here's some rocker switches that look similar.
"THE FIX"
'93 2556
Misc. projects thread https://www.baylinerownersclub.org/f...56-gctid789773
I think they used those on the last Apollo mission and then Teac had them for awhile on their reel-to-reels.
Seriously though, that's a tough one. Sometimes there may be an electronics / HAM shop nearby that might have a trove of switches, but you might end up having to switch over to a newer Carling switch.
"billfnh" post=802709 wrote:
Does anyone know where I can find replacement switches for my Mainship? I cant find them on ebay or west marine. Any thoughts? The pic shows the switches I am trying to replace with the same style.
Bill
[attachment]35075 wrote:
20170309_144155.jpg[/attachment]
I'm thinking that the center-to-center screw pattern should be the same between manufacturers.
Take a look here.
http://shop.pkys.com/Rocker-Circuit-Breakers_c_83.html
Rick E. Gresham, Oregon
They are in fact circuit breakers. Would cost a fortune to swap them all over. Was hoping someone knew of a boat salvage yard that would have something like this. I checked with some of the larger boat yards but no luck.
Circuit breakers, These will probably fit but there not going to match your current ones.
"THE FIX"
'93 2556
