I have a Contessa 2850 with a single VP 260 engine. The water pump could use replacing but I can't get a good number off of the part.
Can someone please verify the part number so I can get the exact replacement ?
What I can read is only 841, the rest is worn off. The cover is also stamped with 8508.
Upon scouring the internet, I got these numbers.. 841640 / replaced by 857451.
Now I also read that if the boat was in fresh water it should be running a higher volume pump. (WHY???) If so, what is that part number?
Thank you!!
JJ
Thank you!!
JJ
