I'm looking for options to replace the US Marine one step swim ladder on my swim platform. I'd like to replace it with one that has at least 3 or 4 steps, as this one is a joke and more than one person has been hurt on it, including myself trying to climb on the boat with it. Everything I've researched looks like it has to be attached to an extended platform, which I do not have. Any suggestions? Thanks.
Swim ladder-gctid802591
https://drive.google.com/open?id=0B0...FCeldnZG40TEFV
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
Can I simply remove the one step ladder that's built inside the platform right now and drill in as a direct replacement for any of these? It seems like I'd have to drill new holes, and I'm concerned the new installation wouldn't be able to support the weight.
MMSI: 367637220
HAM: KE7TTR
TDI tech diver
Kevin
In our cast the ladder bolts to an aluminium plate about two by three feet. There is another plate under the marlin board (swim platform), and the two plates are bolted together.
We had this ladder on a different boat with a teak platform, and this one for over ten years. No issue with support, even climbing up with SCUBA gear.
Dear Slice of Life: Since new, we had complained of the ladder on our 2007 325. My wife and I have adapted "cat like" balance and used the "touch and feel" method of exiting via ladder. Many of our friends with any sort of disability have difficulty trying to desend the ladder
Dear Slice of Life: Since new, we have cursed our 325's ladder. It's hidden under the swim platform and on going down the ladder one must use the "toe touch and feel method" to find each step on the ladder. My wife and I have learned to use "cat like" agility to navigate the darn ladder. Many of our friends with any degree of disability have complained about the ladder. I actually contacted Bayliner about this years ago, and Bayliner was not sympathetic. I guess it's a cost item. So you are not alone. Wishing you the best, Griff.
I completely agree Griff, that undermount was the worst ladder ever. When I got a bigger swim platform I specifically had the ladder mounted on TOP this time. Make sure you can easily get to it whatever you do. Maybe some type of swim platform is the way to go here. A generic one that has one in it already. Would give you another stepping point too'
Making Memories
2007 Bayliner 325
Dual 350 MAGs on Bravo III
