PLEASE HELP SUPPORT OUR SITE
If it is, as you say, a few cc's, you will probably spill more than that trying to add some back in. However, the challenge is how to confirm you only lost a few cc's without opening the vent screw. FIWM, I'd check it to confirm the level and add if it really needs it or change it out if the loose screw allowed water to be sucked in as the drive cooled after using it.
Edmonds Yacht Club (Commodore 1993) 1988 3818 "GLAUBEN”
If the screw was not completely tightened then water could have been ingested into the unit. When is the last time you changed your gear lube? If not recently I would suggest draining and replacing anyway.
1998 3055 Ciera
(yes, a 1998)
Previous boat: 1993 3055
Sea Doo XP
Sea Doo GTI SE
"mattysboat" post=802539 wrote:
It was changed couple months ago, and only took it out few times
One time us all it takes to get water in it. You can try draining a bit to see what the condition is. If you get water or the oil is milky, change it. A bit of time and money now can save you thousands.
2013 Boston Whaler 130 SS
Isla Verde, PR
Be sure and replace the little rubber washers on both the vent plug and the lower plug. Get the proper washer, they're only $1. Without these washers the unit will leak/take on water.
Bob Hawes.
Kelowna, B.C.
1998 Trophy 2052 WA
4.3 Vortec, A1 G2
