Hello all,
I own an '83 Bayliner, cuddy 17.5 ft, Inboard Outboard Mercruiser 470, with 170 hp.
I am currently having issues with my blower and bilge pump. I took the boat into the mechanic and had the engine puled to attempt to locate a tick i was hearing under slow idle. However once the engine was re-installed, I noticed the bilge and blower no longer worked. I have checked all the fuses behind the dash and they all appear to be intact. However, I am uncertain if there are inline fuses and if so where might they be?
If it isnt the fuses, any tips on how to change out the bilge?
Thank you.
83 Bayliner, 17.5 ft,470 hp
Thank you.
