Steering help....-gctid802366
    The steering on my 1995 Trophy 2002 is VERY tight. It turns, but it takes some muscle to turn it. I saw what looked like grease fittings on the cable near the motor. Is it as simple as just greasing it up? Or do I just need to replace my steering cable? Thanks.
    Nick
    The grease fitting on the tilt tube greases the pivot points of the tilt tube only. I had a similar issue with my 1800 years ago. A Steersman steering guard resolved my issue. It's easy to install and keeps your steering cable greased and the corrosion out. My steering never felt so good
    Goes here.
    "THE FIX"
    '93 2556
    Misc. projects thread
      Think this would solve my issue, or is it too late? If needed, could I just buy a new steering cable and run it from the wheel and back to the motor? I am looking to fix this before the striped bass season really takes off here in my part of NJ. Im always afraid something may happen with my steering since its so stiff.
        Don't know where your located, pull the cable take it down to lockwood, and match it up.
          Nick, please fill in your profile and/or signature. It helps others know what kind of boat you have and what geographical area you are in.
          I don't think that you need a new cable. You need to pull the cable from the tilt tube. If there's a lot of corrosion inside you may need to tap it out carefully. Then get a shotgun cleaning rod, brush, and mop. You can also buy a dedicated steering tube Cleaning brush and/or reamer. Use some solvent and the cleaning tools to clean the inside of the steering tube. If it's badly corroded and you do not have a reamer, you can use some sandpaper taped to a rod, attached to a drill. Clean the steering cable and lube it lightly with grease or oil. Do not use a lot of lube because it can cause a hydraulic lock. Put it all back together.
          Look up, cleaning an outboard tilt tube in youtube. There are a few videos showing the process.
          2013 Boston Whaler 130 SS
          Isla Verde, PR
            Don't hammer on the end of the cable. It will mushroom and make it more difficult to get though the tube if not impossible. If you have to tap on it use a wood block to protect it. When mine was frozen I used a heat gun to heat the tube. Put something between it and the fiberglass to protect it. Mine was seized if yours is just stiff it may not need such drastic measures.
              I am not far from you Chief Alen, I am in Monroe.
                MT Jeff, I do have my boat year/make/model in my signature. I will add location next. And thank you for the advice. I will try that.
                  Good advice, thank you. I am going to disconnect the cable from the motor and see if it turns freely then so I can figure out if it is the cable or the engine pivot that is tight.
                    Look under my avatar.
                      Looks like my tilt tube needs cleaning, the old grease in there is all caked up. My steering cable it free when I disconnect it and turn the wheel and feels smooth. Will be cleaning the tilt tube and then using white lithium grease spray to re-lube it and get it back to smooth. Thanks everyone for the help!
                        Took apart the tilt tube/steering cable. Cleaned and relubricated it all and it is like a whole new steering system now. Its great! Thanks for the help guys.
                          Awesome! Now that it's cleaned up you'll likely be able to apply sideways force to the OB engine and have it spin the wheel. Look into the steersman gaurd for ease of future lubrication.
                          "THE FIX"
                          '93 2556
                            I am able to rotate the motor now completely freely! It is great!
