When I pulled my bravo 2 leg off in the fall it was very hard to get off. I have noticed some wear on the teeth of the input shaft also. Now it's spring and I just went to try to use my new alignment bar and it will only engage into the coupler 1 inch. I've been raising the front mounts almost to the point of running out of threads on the mount stud. Still goes in one inch and bottoms on something. Sounds like metal to metal contact. Solid. Looking at the grease tracks I do now have them looking fairly even. Seems like I need to raise the front a bit more yet. But close. The teeth marks were heavy on the bottom to start so the alignment was off.
What could be hitting? It's solid contact and I can not even tap it in any more than an inch.
It's a 1995 2859 7.4l with bravo 2 leg. I've been looking all over the Internet but can't seem to find anything quite like what I'm experiencing.
The tool I bought has 3 steps. The first small portion that engages the coupler is approx 2 1/8 inches long. Next step is approx 2 3/4 inches long the steps up to the portion that engages the gimbal bearing.
What could it be bottoming against?
