The thru hull fitting looks good but that seacock valve was frozen. I remove the old valve. The thread from the thru fitting is good. Trying the replace with new seacock valve.
My question is when threading in new seacock valve to fittings, do I use 3m sealant on the thread or teflon tape for the threads?
