Labored engine starting-gctid802294
    I have noticed my engine when starting has started to sound labored on the starter motor when turning over, initially when you turn the key it turns over the engine what sounds like barely enough to fire it into life, the same sound as if the battery is on its last legs.
    I changed the batteries and still the same problem, however i have noticed that on the main battery bank switch, if i start the engine in position 1 with the left battery it does the same and same with position 3 if i use the right battery, however if i use the no.2 position which uses both battery banks it starts fine without any of this labored engine starting.
    I checked the battery banks and both are at 13.0v so fully charged, its almost like it cant draw enough amps to spin the starter motor properly, i am beginning to think the starter motor is at fault or possibly the starter motor connections.
    What do you think?
    Check the ground where it attaches to the engine.
    Boatless at this time
      +1
      Also make sure the starter motor connections are very clean and shiny. It sounds like a dirty electrical connection to me.
      2004 Bayliner 285 350 MPI Bravo III
      2007 Bayliner 192 Discovery 3.0 135HP (sold)
      2000 Ciera 2455 sold
      Redmond, Washington
      The one on the Left (Wet) Coast
        Did you clean the battery posts? Or just check the voltage. The classic in my experience is oxidation on the terminals.
          Had the same problem with my Port motor.
          Laboring and showing the same symptoms you have described
          Did all the checks as listed above.
          New starter motor fixed the problem, and they are not expensive.
          Once replaced motor spins over fine.
            Thanks for the info people
              Also check for corrosion under the insulation near the terminal ends. The corrosion has a way of working itself under the insulation. This may not be the problem, but if it turns out that your starter is faulty, this sometimes is the reason. If you install a new starter, it may start fine, but you still may have high resistance in one of your cables. Just don't want to see you have to replace the starter twice.
              Joel
              1987 3818 Hino 175
              "Knotty Girl"
              Prince Rupert B.C.
                +1 sounds like cables. Negatives most likley, look where they come together (engine block or negative buss) Sounds like when you combine batteries you start just fine, and you say the batteries are new.
                "THE FIX"
                '93 2556
                Misc. projects thread
