Okay I am going to make the change. Take the bad 8D out of the starter position and replace it with the good 8D house battery. Then I will replace the house bank with 4 6v golf cart batteries. In my area Sam's is giving me the best price. Here are the specks on the batteries:
20 amp hour rate:215
5 amp hour rate:157
6 amp hour rate:156
Battery Electrolyte Composition:Acid
Battery End Type:Top Post
Battery Purpose
eep Cycle
BCI Group Size:GC2
Contents:ONE EACH
Freight Class:65
Minutes at 25 amps:395
Minutes at 75 amps:105
Terminal Type
IN
Volts:6
With these hooked up as two twelve volt batteries and wired together to make one large twelve volt battery and my max draw is 6.5 amps, how long should I be able to go before I need to charge the batteries?
5 amp hour rate:157
6 amp hour rate:156
Battery Purpose
BCI Group Size:GC2
Contents:ONE EACH
Freight Class:65
Terminal Type
Volts:6
