Hello,
I am having problems with my water pump, and I don't know much about how they work.
It started not functioning after I filled the tank. So I'd go out, fill the boat with the hose, come back inside, turn on the faucet and nothing. I've tried flipping the water pump switch on and off...nothing. Then magically it would turn on maybe an hour or so later.
This happened once, then worked normal a few times, then happened each time. I've filled and run the water out to clean the holding tank twice in a row, and the third/last fill resulted in no water.
The last time the pump worked was this morning; I washed the dishes, went about my routine, came back to the boat and no water. The pump won't turn on.
I've only had this boat for about 3 1/2 months, and I can't find the original manual or purchase date for the water pump. The wires all seem to be in place and the fuse isn't popped out. There is some water underneath the pump.
I'm not sure how long the pumps normally last. I found the manual online however, and followed the instructions for operation and fill....still nothing. Any ideas?
Thank you in advance.
