This is not what I wanted to see! Am I screwed?-gctid347605
    Pulled the lower unit today to replace the impellor. There is major corosion between the water intake port and the exhaust port. If I were to put the new pump back in with just the gasket there would be a quarter inch gap between the gasket and the housing. Is there anything that can be done to salvage this or am I now looking at replacing the lower unit or LU housing?
    [img]/media/kunena/attachments/vb/650379=24235-water pump area 1.jpg[/img]
    [img]/media/kunena/attachments/vb/650379=24236-water pump area 2.jpg[/img]
    http://baylinerownersclub.org/media/...ea 1.jpg[/img]
    http://baylinerownersclub.org/media/...ea 2.jpg[/img]
    The housing is dead, try some boat salvage yards or ebay.
      I have res-erected quite a few of the that looked worse than that !A bead blaster and jb weld and a paint job it can be fixed .The pits is a normal thing for mercruiser in salt water and zinks not been serviced properly .The question was am i screwed ,well your mechanical skill will determine that . If i could find my pics of a few i did i would post them.
        I have also seen and heard of housings being repaired rather then replaced. either jb or welding up the the damage and grinding/re-shaping. not always worth the repair if lots of hours or any doubts or other issues with the drive, sometimes better to start over IMO.
        good luck
          Wow. If it was me I would replace. But trying to repair woud not hurt. Worst case is you can't repair it. I have a A1 lower unit that needs a prop shaft seal that I plan on doing someday just to say I have.
          1998 3055 Ciera
          (yes, a 1998)
          Previous boat: 1993 3055
          Sea Doo XP
          Sea Doo GTI SE
            I have heard & read good things about the SEI drives: http://www.sterndrive.cc/
              I took it to a couple different welders and they said no way.
              900 bucks later, I've got a new SEI lower on the way to the house. I guess I will see if I can part out the one I have or just keep the gears for parts.
              BTW,
              SEI sells a lower case but it is $100 more than their complete lower. When I asked them why they said they didn't want to be in the case selling business. I guess that is one way to handle it....
              Jason
                BTW,
                Jason
                When welding alum that is salt water exposed it pops and crackles.
