I have the Lowrance HDS Gen2 12" touch, getting ready to add their Chirp Sonar Hub. Can not make up my mind on which transducer to use. Has anyone had experience using this Chirp Sonar and have any comments on it and recommendations for a transducer. Thanks
Chirp Sonar Hub-gctid801674
I have simrad setup with sonar hub as well. we Scuba dive manly so we we went the structure scan and a Forward scan as well a chirp. You need to decide what you want to see (ie Structure or Fish) and what depth ranges are most important. In our case we wanted the most detail at the 0-150 range so choose ours based on that. Most allow for a few frequency options so we can adjust them a bit.
Not sure that helps you a ton, but Chirp is much more detailed and what ever you choose will be amazing to a standard old school transducer.
Mark
USCG OUPV
1990 4588
Carlsbad, CA
It looks like I'm going to stay with the 50/200 that I have as Lowarance says it will work fine with the Chirp Sonar Hub. Will try it out and if not happy will try a different one. I' also getting the LSS2 structure scan to replace my old LSS1. The new one will go through the same hub as the Chirp, so can get rid of the old LSS1 hub. My boat is still snowed in in storage. Went and checked today and hope weather permitting in 2weeks I can get it home and get the changes made and then in the water.
1999 2859 Volvo D4 260 DPH:arr
