Hello All
Only my second time posting here as I just found this handy group. I own a 2006 Bayliner Discovery with the 3.0 4 cyl mercruiser motor. Had it most of last year and ran well. I had it winterized and serviced at the dealer. I've been out about 7 times this season with no problems. We trailer this boat. The past couple trips there has started to be a problem starting. I want to fix it but it is intermittent so far so I'm hoping to get some opinions.
On the first key turn of the day it won't start. There is a single click and nothing else. try it one more time and it might click or it might start... (SO FAR) try it a third time and it starts. We use the boat all day with probably 2-3 starts and no problems. On the last trip I have engine cover open waiting for click or no start every time during the day and it just fires right up. Last night while on the trailer I had my wife try to start while I was listening at the engine. It did the single click at the "slave solenoid" mounted on the block. I grabbed a test light and a handy write up of how to trouble shoot this condition and had her try again only to have it start the second time. I tried multiple times and it turned over every time. While I had time I cleaned and tightened the battery connections and the starter connections and I checked the push on connections to the slave solenoid (the heavier wires were fine)
I have a slave solenoid on order as I figure for $20 it wouldn't hurt to have it if I need it.
My question is how do I troubleshoot something that only happens once or twice a day? I'd like to fix it before I get stranded.
Thanks in Advance
Brian
Thanks in Advance
Brian
