12V engine auxiliary power... I am stumped! Any help would be much appreciated!-gctid801327
    So I had a short on my battery the other day by accident.... I blew the fuse I had on my battery terminal....
    Now the 12v power from the engine wiring harness is dead... I traced it back to the engine...
    I get a zero reading on what appears to the the engines circuit protection, which has or did not trip.....
    I have tested the battery switch wire outputs and all read a healthy 13.7V .... so this tells me the problem is between the engine to power connection and the engine power wiring harness connection point coming out of the engines circuit breaker..
    Any assistance would be greatly appreciated.... I have been at this for 4 hours and am stumped! Thanks for the help
    BOAT: 1991 - Bayliner 2556 Ciera Flybridge
    ENGINE: 357 Alpha 4V (275HP)
    OUTDRIVE: Alpha Gen 1
    RATIO: (to be updated)
    PROP: 15 1/2" X 15P
    Marine Search and Rescue Crew - http://rcmsar.com/rescue-stations/southern-region/north-vancouver/
    Pics
    PROP: 15 1/2" X 15P
      Ps. I also have strong voltage reading on the starters solenoid.
      Thx
      PROP: 15 1/2" X 15P
        90amp fuse at the starter blown...
          I this it?
          PROP: 15 1/2" X 15P
            Yup,
            Should've asked sooner...could've saved you 4 hours.
              Lol... so true! Is a nice day though.
              Thx!
              PROP: 15 1/2" X 15P
                Anytime bro...not bad today, looks like you're in the PNW too.
                Happy boating :cheer:
                  [attachment]34847 wrote:
                  1490993231119-1663742490.jpg[/attachment]
                  That looks like Horseshoe Bay. I lived in Vancouver for 11 years. In fact, they put the fireworks on just for me! They asked, and I said, "As long as it isn't too loud, and you clean up after yourself...." :whistle: Miss it dearly.
                  Where are ya?
                  MMSI: 367637220
                  HAM: KE7TTR
                  TDI tech diver
                  Kevin
                    Indian arm area....deep cove BC
                    Good eye!
                    PROP: 15 1/2" X 15P
