quadrajet replacement-gctid801184
    I have been laid up and just now getting back to my carb problem. Its a 94 2655 with a sick carb. Everyone told me that Holley was the way to go so I tried one. Problem is the carb hits the housing for the thermostat.
    If I try to raise the carb everything else is has to be rigged to get it to work, linkage etc.
    1) Has anyone else had this problem and if so how did you correct it?
    2) Has anyone used a different carb with better results?
    Edelbrock 1409, and you won't have the float bowl issue.
    "THE FIX"
    '93 2556
    Misc. projects thread
      +1 Edelbrock 1409
      Pat. Sandpoint Ida
      I NEED ANOTHER BOAT!!
        +1
        And the Edelbrock in my experience is a better carb.
        1988 Mainship 36 Sedan
        1995 2858
        1988 2655
        1987 2150
        Commercial/Industrial HVAC Service Tech.
          I have a good used 1409 with flame arrestor and owner's manual that I can sell you if you like. I've switched to diesel engines so no longer needed.
          1990 3288 twin 150 Hinos
          previous: 1964 28' Owens express cruiser, v8 crusader
            1989 Avanti 3450 Sunbridge
            twin 454's
            MV Mar-Y-Sol
            Twin chevy 350's inboard
            Ben- Jamin
            spokane Washington
              yep Edelbrock 1409 ,had to get a different flame arrestor and some modification work on it ,when the engine cover was put down it was resting on the flame arrester
              1988 flybridge trophy bayliner 2556 ,mercury 5.7 lit. OMC cobra out drive 76 hrs. on new package,
              located in ketchikan ak,name DOMINION
                The Edelbrock would be a good choice. You will need an adapter or manifold swap as you may know to go from spread bore to square bore. Don't use an open style adapter, they have their uses but a heavy boat isn't one of them. Use a divided spacer like Edelbrock 2696. Since all the Quadrajets are old getting a good one is getting hard. Stay away from mass rebuilders. I grew up with Quadrajets so I am biased and can do my own work. New carbs always seem to work better anyway. And have a warranty. Oh and the Holley carbs have had their own issues.
