bayliner 192 discovery blower-gctid801177
    need help. blower stop working, check fuse under helm, all good, connect blower directly to battery and its working. any other fuse in line? or bad switch?
    You should check to see if you have 12 volts to the switch and then see if you have 12 volts out of it when you have it switched on. The backside of the dash is a easy access on the 192's as you should know by now. Just keep working your way back to see where the power is dropped.
    2004 Bayliner 285 350 MPI Bravo III
    2007 Bayliner 192 Discovery 3.0 135HP (sold)
    2000 Ciera 2455 sold
    Redmond, Washington
    The one on the Left (Wet) Coast
      Switch gone bad.
