Last season I had my steering cable on the 1950 with rack and pinion replaced. Used it today and the helm is very loose and requires constant correction. Before I head back to the dealer, is there a simple adjustment to "tighten the wheel".
Helm wheel to easy-gctid801153
I would first contact the dealer if you didn't use the boat after having the cable replaced. There is a tensioner on most of the steering fittings on the bottom. It just a plastic wheel bau acts like a brake. Also, you may need to adjust the trim tab on your drive to neutralize the prop torque.
