Aluminum Zincs-gctid800890
    Hi, My Zincs dont last a year, due to my marina I think. Apparently alluminum lasts 30% longer with the same protection. Could you share your experiences with me please.
    Thanks Bruce
    My port trim tab got ate up last year because my next door boat had not had the zincs replaced for 5 years, she is gone now, thank god.
    The one year I did not hang a transom zinc between us.
    Have you checked your bonding system?
      That's incorrect. "Lasting longer" and "same protection" are inverse. An anode provides protection by being dissolved away by electrolysis. If it's not being eaten away, it's not protecting you're more noble metals. It's the DC current produced by the dissolving anode that counteracts the current of your dissolving stainless bits.
      It's all about ion flow and keeping the reduction on your sacrificial anodes, rather than those more expensive bits.
      iBoatNW
        Here's a great article explaining the differnt anodes, applications and how to test for corrosion (video).
        http://www.boatingmag.com/how-to/cho...rificial-anode
          Thanks Bruce
          I see you're in Qualicum Beach so if your boat is there it will be moored in salt water. I think Zinc would be your best choice for anodes. Aluminum is more for brackish water which is fresh and salt water. We moor a little up the Fraser River so we run aluminum anodes.
          Sea Venture
          2000 3055, 5.7/B2, 18x23" props
          Cruising the PNW and beyond.
          DIYC, Riverhouse Marina
          MMSI 316029971
          Kirk
          Drinks well with others.
            https://imageshack.com/i/poEM6LRZj w....jpg[/IMG]
              Thanks I am aware of this. Appreciate your input.Just trying to slow it down to once a year.
                Thanks I found this chart on Martyrs site I think
                  I only use Martyrs...best premium grade.
                  Aluminum anodes for all Mercruiser stern drive.
                  What you got 3988 ? Then yes Zinc would be your best choice.
                    Add more/larger anodes.
                    Jeff & Tara (And Ginger too)
                    Lake Havasu City, AZ
                    Current: 2008 Playcraft 2400 MCM 350 Mag B3
                    And 12 others...
                    In memory of Shadow, the best boat dog ever. Rest in peace, girl. 7-2-10
                      Agree. Don't change the type. If you're trying to stretch them out, get a couple of zinc fish to hang over the sides.
                      iBoatNW
