My 7.4 liter Mercruiser starts fine when cold. One short starting try to fill up the carb, then it fires right up on the second try. After it has been running, if I shut it down, it is difficult to restart.
The engine turns over fine, but the ignition won't catch. I usually have to hold the throttle wide open and crank for at least ten seconds before it will catch. Two mechanics have been unable to help. New plugs, wires, coil and distributor in the last year. I only use ethanol-free gas. The engine is a 1996 vintage with a carb, not electronic ignition.
I welcome your suggestions. If I keep this up, I think I'll be adding a new starter soon!
Rob
Rob
