2001 5.0 carbed m/c. Seems like my temp alarm comes on way too soon lately. Like around 5* above op temp.Normal op temp is needle on middle of the "5" on 175 on temp gauge. Alarm goes off if it gets to rh side of 5. Occurrs sometimes on slowing to idle after a long run,etc. Could be a pump issue but it seems to me alarm shouldnt be coming on till 200 or so?I am fw cooled and have a 190 therm installed. This never used to happen so something has changed. Either Im not pumping as much rw as before or alarm sensor has gone off its spec. im thinking. I am about due to change rw impellor but there are no indications of gradual or slight overheating while running as I would have expected if imp on way out.Any thoughts anyone?
Specs for alarm sensor?
