I have a 2005 185 with a 3.0. I have had the carb rebuilt due to ethenol problems.
The boat runs great hot or cold. The small problem is when starting. Again this happens hot or cold.
I pretty much have to prime the carb with 4-5 throttle pumps and then hold the throttle lever all the way down while I turn the key. Even then I have to hold the key in the start position for several seconds before it catches. Also the boat does not like to iddle for any length of time. Yesterday I was waiting in line at the ramp and had to restart it several time. Then as I was
Pulling in it died as well. This is after a full day of running with no issues except when i shut off and try to restart.
So I was thinking maybe the choke or maybe the mixture is to lean but need your advice.
