Hi guys (& gals),
I recently replaced the twin POS Force 125hp motors on my Trophy with a single Yamaha 225hp 30" shaft oil-injected model (1992).
Here's the deal, I have over 100 gallons of premixed gas in tank which is still good (yep, over $400 in gas and 2-stroke oil). I don't want to throw fuel away at recycle dump, so was thinking about temporarily disabeling oil injection until I use up most of gas. Once I get down to maybe 10 to 20 gallons, I was going to add more fuel so I no longer have a 50:1 mix.
Also, I am not too sure if a little oil in gas would affect using main tank to feed my 4-stroke kicker. If that's the case, I may have to use up or empty tank completely and start with pure gas.
Can anyone tell me how to disable oil-injection temporarily? Or would I be better off dumping premix gas and start with pure gas?
I am sure some of you may have run into this before, so any suggestion would help.
If I need to get rid of premixed gas and if anyone is in Kitsap County Washington, let me know if you could use this gas.
