Will house bank charge off the alternators on a 2003 305-gctid396021
    It occurs to me I've never been away from the dock long enough to worry about this..Would you guys expect my house bank to charge off the engines alternators? I sure think it would, but for some reason I have a vague nagging memory of the previous owner saying he didn't think so. I'm also searching for some justification to go buy a Honda EU2000i
    Unless it was alltered or never set up to to be in the system yeah the alternator will charge the house. If not it would ne easy enough to set it up to charge. You may have to jave the battery switch set to "all" to charge them. But then you never rrad this you really need a generator.
    1989 Avanti 3450 Sunbridge
    twin 454's
    MV Mar-Y-Sol
    Twin chevy 350's inboard
    Ben- Jamin
    spokane Washington
      I think each alternator charges a separate bank. My starboard engine charges my house bank.
        Here are a few easy solutions if your MBSS is not set up to do the trick.
        ACR p/n 7610.... 120 amp rated
        ACR p/n 7621 .... 300 amp rated
        Automatic Charge Relay p/n 7620 is rated at up to 350 Amps, and is also an automatic battery combiner.
        Automatic Charge Relay p/n 7622 is rated at up to 500 Amps, and is also an automatic battery combiner with lock-off capability.
