PLEASE HELP SUPPORT OUR SITE
Thanks!!!!
new to bayliner ownership... need help ! won(39)t start-gctid396017
Should be by throttle. Little pin that needs to be held out
Boatless at this time
+1 kill switch? The most common problem for non-starters.... Mine even kills the engine if it looks like it's in the correct position.. I have to push it really up to make sure it gives contact.
Is it a Force outbord, or a Merc? It's a big difference!
If it is a Force, it is actually what the Chrsler outboards evolved into, and has nothing to do with Mercury.
Check out the Iboats.com Chryser/Force forum...they have some experts out there.
Again, if it's a Force, it's likely a prestolite CDI ignition, and the troubleshooting is different than any points style ignition system. Are you looking at a 4 cylinder, one coil per cylinder?
Ifr so, to shut down the spark they actually short the 'magneto' source to common, otherwise it will run forever!
Teleflex Marine is partnering with iboats.com to offer an exclusive field test for iboats.com Forums members for a new product line called XTREME Mechanical Steering. We are looking for 10 participants who have boats that fit the following specifications:
-Pontoon and center console boats...
Hello - I am new to this forum but a longtime boat owner. Unfortunately I have to start my first thread with a tech question and I'll try to keep it short and direct. Last summer my 50 HP Force died - no spark from either coil but power everywhere else. I got it in the shop a couple weeks ago...
I have a force motor 2235. thanks for the wiring diagram. when I bought the boat the guy broke the kill switch, he replaced it with a screw. Sometimes the boat will run perfect. I figure it is something simple, I'm just over looking it...
Hell I don't even get any reading on my volt meter,going this morning to get a new one try it again. and replace the kill switch. I'll let you know if it works
