Looking to fill up a toolbag for the boat... aside from a flare gun, any must have tools for a river repair?
Toolbox must haves...-gctid347446
Spare engine belts is typically the #1 suggestion, and the tools to install them.
My suggestion (based upon my electrical issues) is a digital voltmeter and spare battery for it. Spare wire and wire crimping kit, and fuses also.
By the way, you should add your boat info to your signature. That helps us more quickly (and more likely) answer your boating related questions. Updating your geographic location also helps.
Enjoy!
-Jorden
You'll want a prop nut wrench and a method to release the locking tabs (assumming that you carry a spare prop). I've changed a prop in the water a few times, but it does depend on your boat. A very sharp knife, side cutters, a spare impeller and related gaskets (depending on where you boat). Spare container of leg lubricant (if you have a reservoir in your engine compartment, assumming that you have an inboard). You mention flares, which aren't really tools, so I'll also mention ALL required safety equipment.
Bob Hawes.
Kelowna, B.C.
1998 Trophy 2052 WA
4.3 Vortec, A1 G2
The flare gun was for signalling someone that has the right tools to help me fix the problem.... i do have an inboard... im tryin to update my boat info.
A cheapy volt meter, length of wire(s) for testing, oil wrench, philips and slot screw drivers, wood plugs, toilet wax ring, spare blue wing engine block plugs, spare spark plug, impeller & tools required to remove housing, spare hose clamps (various sizes).
Doug ;}
MMSI: 338068776
sigpic
I also carry a few spare spark plugs w/ nessasary tools to replace them. A small spool of wire. A small file and emory cloth.
Oh I love these....
My bag contains:
Spare ignition module
Spare coil
Spark plugs
Voltmeter
Fuses
Flashlight
Baby food jar of various crimp on elect terminals
Crimper
Lengths of 12ga wire with alligator clips on both ends(very handy)
Impellor kit
Timing belt and spare cross piece-Volvo OHC 4-cyl specific parts
V-belt
Alternator
Fuel filter
Thermostat
Cap and rotor
Roll of shop towels
Hose clamps
Zip ties
Electrical tape
And tools to R&R any of the included items.
Murphy's law says the one thing I am missing will fail....so.....I don't give it a chance.
apexaro1 wrote:
Thanks Doug, what is a wood plug?
whiskywizard wrote:
Old habit... When he started boating, spark plugs were made of wood.
rkcarguy wrote:
Oh I love these....
My bag contains:
Spare coil
Spark plugs
Voltmeter
Fuses
Flashlight
Crimper
Impellor kit
V-belt
Alternator
Fuel filter
Thermostat
Cap and rotor
Roll of shop towels
Hose clamps
Zip ties
Electrical tape
apexaro1 wrote:
Where the heck do you stow all of that?
The wire with alligator clips has been the biggest savior. I've bypassed a stuck neutral safety switch, bad relay, and bad ign switch with it in my 3 years of boating.
