I've seen what appear to be cable clips on some pics of transom mounted transducers, but for the life of me cannot find any. Anyone with a link for a good way to secure the cable to the transom?
Secure transducer wire to transom?-gctid395607
Hi
I would use P clips which are much better, but if you have to use cable clips then I would remove the nail from the cable clips and used a stainless screw, use the correct size drill and pilot the transom, use a bit of insulation tape or similar on the drill bit to mark the depth that you need to go, squeeze some quality silicone into the hole and insert the clip and don't overtighten.
Same really as when putting on a transducer or similar.
Regards.
