I pulled into a hangout today and just as I got to my spot and put her in neutral the engine died I thought that was odd but wasn't to concerned at that point. When setting the anchor the winch sounded a little weak so I thought about the battery being discharged so I turned the ignition switch on and sure enough they appeared to be deader then a door nail. I started my gen in hopes of the on board charger would charge the battery's enough to start the engine and get me home but to no avail so after being towed to the docks and loading the boat on the trailer and getting back home I'm at the point where I need your input please. All of the 12 volt circuits are dead I was thinking there is a main ignition breaker in the engine compartment but all I can find is a auto reset and I don't even have 12 volts to that. When I turn on the key switch theres no movement at the gages and no dash lights, the 12 volt overhead lights don't work. I do know both of battery's are 1 year old and all the connections on them are clean and tight. Whats your thoughts on other possibility's or places I should start checking
Thanks Doug
Thanks Doug
