The only tag on my outdrive gives the model #985273.
It says engine 5.7L. and Serial # T0604940.
That tag is on the upper housing. There is no tag that I can find on the lower housing. It does look like the previous owner replaced the lower as its a different color than the upper.
I'm trying to find the correct prop for my boat. The current 15x15.5 is only giving my 3400 rpm at wot. My 2655 was topping out at 23 knots. It should go faster, right?
Greg
Greg
