I have a 1996 Bayliner Capri with a 3.0. The boat was running great and then we stopped for about an hour to swim and it would not restart. Had a problem similar last year and put on a brand new carb and coil it has bee n fine. Is there a problem with the coils on these? thanks
1996 Bayliner 3.0 wont start when hot-gctid394198
brimar14 wrote:
... we stopped for about an hour to swim and it would not restart....- Does the starter crank the engine ?
- Is there spark?
- Can you see/smell gas in the carb?
- How long does it have to cool before it starts?
brimar14 wrote:
.... Had a problem similar last year and put on a brand new carb and coil it has bee n fine....- Are you saying changing the carb and coil did not solve your hot starting problem?
- Is this an intermittant problem - does it happen every time the engine is hot?
I had changed the carb (weber) and coil(sierra) last year and have had no problems until now. After about 3 hrs I was able to start it again. It had spark but it looked more orange then blue or white.
You may search for threads where others have reported the same issue. They come up from time to time. As I recall, often the problem is an electronic component, but you should double check the solutions others found. Does you boat have an electronic control module?
You may also want to check that your oil pressure switch, thermostat sender, and operator toggle switch are not at fault by shorting when they get hot. If you can duplicate the problem at the dock then it will save you headaches on the water.
Throwing parts at the engine is not the way to go. When the engine doesn't start are you missing spark or fuel ?
brimar14 wrote:
The spark seems to be orange in color which leads me to believe it is spark. The fuel is seems to be fine
