The PO of our boat went nutz with black spray paint... seems to be all over the carb too, so I am considering rebuilding both of them for I am sure the other looks pretty much the same. Why someone would remove an aresstor to paint carb throttle plates is beyond me.
I decided to poke around post Christmas eve all day ride... was very calm and nice. Discovered a leaking oil hose going up to the filter. Seems to be 2 oil hoses per engine, send to filter and return. Down about a quart on the port engine, with about that much in the bilge. Used one of those soak up thingies to clean up a bit. Several questions:
Can you tell the year of a hose by its labeling?
Is it common practice to replace all oil hoses at once? Not sure how often these will fail, although rated at 250psi... Failed at the compression area.
Would you rebuild a carb that looks like this?
Is there a rubber piece or gasket that is supposed to go between the carb and arrest filter?
Thank you in advance! I have another thread about fuel pumps and my fuel situation, so please take a look at that one too and comment. Appreciate all the help that can be had here, what a great group!!!
Jim
Attached files [img]/media/kunena/attachments/vb/643322=23251-carb.jpg[/img]
Jim
